vintagetools
- Mar 11, 2013
- lutz florida
I'm using a Fitch Williams design. I can start a 3 hp buffer. But my 15 hp + 5 hp will not start my 7.5 hp compressor. Its a Ingersoll Rand 1 year old compressor I bought new. I had a store bought 3 phase convertor I bought back around 2000. It died but was struggling to run my compressor for the last year. That company was in Alabama and is no longer in business. I cant remember their name. The outside label of that unit said it was a 15hp convertor. But when i separated the panel from the motor, the motor was rated at 5hp? Thats the 5hp in my current configuration. By its self on the Fitch design , no way can it start the compressor. But the buffer it could. I then acquired a 15hp. I now start the 15hp then add in 5hp with its caps to balance.
Ive even tried running the buffer with both other motors and still no go.
I have tried a step up transformer to run my compressor on 480v to drop the amps and still no go.
I bought a scope with 4 channels to try to watch things but that has its own large learning curve.
At some point during all this i had a empty tank and one of these configurations sort of worked. When i stopped it around 100 lbs and tried restating it, no go. I believe mine has the dump valve on it.
I can get balance within 10% of L1 to do all these test Ive done but no matter where I try to watch voltage from, the panel, the idler or load my generated leg voltage will drop to around 115 when running 240v and 145v when running 440v.
With the money i spent on the scope i could have just bought a store bought unit but where is the fun in that.
So I don't understand how my last phase converter powered this compressor with only the 5hp? Everything is still located in there original spots with about 50 feet separating them using the same 6 awg wire.
Thanks John
Thanks John
