Phase-A-Matic rotary converter randomly starts in different direction - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 60 of 60
  1. #41
    Virginia
    31,363
    7561
    9842
    Quote Originally Posted by rons View Post
    They have been using putty to balance rotors for something like 20+ years. Sloppy.
    Well its only a f**king cheap-seats Baldor? I did say "practical joke? What did yah expect?
    Get that crap outta there, bugger rumbles like a Diesel?
    Then he'll see why he should quit wasting everybody's time, his own at the head of the list, start over with a decent idler.... and all the rest!
    You'd have to understand "pragmatic" gold rather than "Phase-a-Matic" trash?
    Kinda neat the damn saw don't run bass-ackwards half the time, too.. but there yah have it.
    "Goals". That WAS the one, yah? Electrical masturbation with a cast of thousands was NOT on the list.
    "Get to the END!"
  2. #42
    Dec 2008
    IL/WI border
    3,426
    1234
    1064
    Quote Originally Posted by Bob-J-H View Post
    Phase-a-matic uses the high resistance rotor method, That is why there is only run caps.
    Aha! Now it makes it clear! So those are custom made 3-phase motors with a start winding for a single phase operation/start?
  3. #43
    Jun 2001
    St Louis
    18,427
    2045
    3219
    Instead, I run either a 12-24 or 1-4-20 not on those aluminium studs. Then screw on different thickness nuts. Usually I use full and half width nuts.
    But I am only doing balance operation on V-blocks. I spend enough time with it to get the best possible result.
    The official method is to load washers on the stud until it balances, then peen over the end to hold them. If balance changes over time, there is a different problem.....
    Both methods work fine.
    I do not like the putty method at all. Epoxy can be used and is a bit better, at least it will stay in place well.
    We gonna get those measurements I asked about?
  4. #44
    Nov 2006
    Camarillo Ca
    511
    35
    118
    Quote Originally Posted by JST View Post
    Quote Originally Posted by MichaelP View Post
    There is no start winding, doesn't need it.
  5. #45
    Jul 2007
    UNITED KINGDOM
    5,030
    2857
    2474
    Umm...
    Putty as a balance weight is perfectly ok in a small rotor, so long as it's a quick setting styrene/epoxy/whatever type. Not very well integrated with a production line, automated two plane balancing setup though.
    Bleed resistors on a capacitor across a motor winding are only needed where idiots might remove covers, to diagnose faults, and not short any capacitors before toching as a amtter of course.
    "High resistance" rotors usually have deep rotor slots so that most of the squirrel cage rotor bar is under the surface of the iron rotor. This increases the impedance of the rotor windings at higher slip frequences while keeping a low impedance at normal running frequencies. Wound rotor motors can use different methods, but not in sub-megaWatt sorts of sizes.
    It's still looking like a dubious connection between the 'motor' and the capacitors OR the capacitors connected across the line rather than connected between the line and the other two phases of the system.
  6. Likes TDegenhart, JST, neilho liked this post
  7. #46
    Virginia
    31,363
    7561
    9842
    Quote Originally Posted by Mark Rand View Post
    Now.. don't even TRY to tell me the world has run short of that very flavour of Idiots.. I'll start forwarding the US backorders to the UK.
    Mind.. way things are going septic side "funny papers", if such orders get FILLED, we could be improving the average IQ of two great nations in one go just off the back of replacing a legion of village idiots as were sent-off to the Yew Ass Congress.
    The fear is that Perfidious Albion would cheat by sending SUCCESSFUL Members of Parliament in trade for US village idiots, and the Septics would be f***ed again!
  8. #47
    Jun 2001
    St Louis
    18,427
    2045
    3219
    Umm...
    Plumber's epoxy is reasonable. stiff putty, will not drip off, and you can easily stick on a bit more, or pull off a bit. Usually hardens fairly quickly, good enough for batch processing special orders.
    My Arco has a double cage.... fat bars buried, and thin ones in slots. His might be that, or a "deep bar" type with large but narrow bars that go deep, similar result.
    Yeah, all it would take is one wire to the wrong place and the caps would be across the incoming line.....
  9. #48
    Mar 2009
    5,602
    103
    1084
    Quote Originally Posted by jariou View Post
    And the bank of capacitors:
    Attachment 288508
    Measure the capacitors individually.
  10. #49
    Aug 2014
    bainbridge island
    1,257
    261
    297
    well you got to admit though that bleed resistors would be effective in hiding the information needed to diagnose the fault in the first place.. which sounds like an intermittent connection.
  11. #50
    Virginia
    31,363
    7561
    9842
    Quote Originally Posted by johansen View Post
    LOL! Hard to defy "intermittent" at sumthin', yes. "Taken as stipulated?" "Chaotically biting the owner in the ass", so to speak?
    What is most effective at "hiding.." "...the fault in the first place" is a two-tone 'loominum and red label.
    Mind there's a broad HINT of feather-merchant'ism.
    It does say "Phase-a-Matic" on it.
    Right in front of God and sorrybody!
    Each of us were to bill our assistance at nought but min-wage, it is already one curious-costly RPC, and still don't even work reliably.
    The GOOD news? Yah don't have to go as far as China to find marginal products.
    'Muricans are still perfectly capable of screwing ourselves.
  12. #51
    Dec 2008
    IL/WI border
    3,426
    1234
    1064
    Jariou,
    Any updates? It would be very interesting to see how the puzzle was solved.
  13. #52
    Jan 2008
    Cary, NC
    210
    95
    41
    Jariou,
    Well, I put the converter back together and yesterday, I rechecked all the connections and found my problem. I thought that I had wired the manufactured leg to the red wire of the converter's tail but I had wired it to the the black wire.
    As I said at the beginning, I was confident I knew how to wire the whole thing. I did, but I made the mistake of assuming rather than double checking.
    So I owe you all a shameful apology along with many thanks to all of you who tried to help me out.
    Thanks to all, I promised to be better next time! ;-)
    Jacques
  14. Likes JST liked this post
  15. #53
    Virginia
    31,363
    7561
    9842
    No fear. "Apology" is built-in.
    "Payback", y'see ... is having to run a third-rate RPC for the next many years!
    And that's a shame.
  16. #54
    Jun 2001
    St Louis
    18,427
    2045
    3219
    Jacques
    If I had to tell you the dumb shit stuff I have done over my life so far, that I knew better than....well, I would not want to..... just leave it there!
    If you have never messed up, then you have never tried anything....
  17. #55
    Virginia
    31,363
    7561
    9842
    The Hell we will!
    But yer YOUNG yet, so .. "still learning and growing", yah?
    Take heart!
    The first hundred years are ...
    .... the EASIEST!
  18. #56
    Dec 2003
    poulsbo, wa, usa
    1,030
    72
    441
    This might sound funny but call "American Rotary" ,,,,,,, they were a big help to me a few years ago when I was trying to fix a rotary that was made by someone else and I was told there happy to help out on other brands ,,, After there GREAT support I ended up buying a 75 HP rotary from them …..
    Bottom line is I support company's that support me ,,
  19. #57
    Virginia
    31,363
    7561
    9842
    Quote Originally Posted by D.D.Machine View Post
    Wise folks. Not alone. Goodwill and good reputation is priceless.
  20. #58
    Dec 2008
    IL/WI border
    3,426
    1234
    1064
    Jacques
    Thank you for the update.
    I'm trying to visualize the schematics where an improper hard wiring would produce such an unusual behavior, and I still cannot. Anybody cares to draw the schematic diagram?
  21. #59
    Jan 2008
    Cary, NC
    210
    95
    41
    Thanks guys for not being too rough on me.
    I wish I understood what exactly was going on there, how that wrong wiring caused that specific effect. But that's not really necessary. It would be "nice to know", but at this point I'm just happy that I'm able to move forward.
    Thanks again to all.
    Jacques
  22. #60
    Jul 2010
    Rochester, NY USA
    2,259
    10
    536
    So the capacitors were across the power company phases (not doing anything useful for this project).
    The black lead was flapping in the breeze with the phase rotation determined by which ever rotation the Pony started.
    It's the little things that getcha!
    Glad you are running now.
    Bill
