Phase Perfect Protection - Page 5
Page 5 of 5 FirstFirst ... 345
Results 81 to 85 of 85
  1. #81
    Virginia
    23,871
    7561
    7505
    Quote Originally Posted by rklopp View Post
    This thread prompted me to go out in the garage and turn on my PT330 and the radio next to it. I don't get any radio interference that I can hear on either the AM or FM dial. I do get slight AM interference from my Monarch 10EE tube-drive modular, and from a VFD that's close to the radio. Some of the leads coming to and from my PP are in plastic liquid-tite conduit, which I don't view as a very good EMI shield. I have not noticed anything weird going on with my microwave, either.
    I am just offering this up as a data point about a PT330 installation.
    I've used the "Sealtite" brand ISTR, on a couple of things around the patch and IIRC it has a thin Aluminium flex layer embedded.
    Uncertain contributor, depending on how terminated or even-IF, but even as a floating capacitor plate, might potentially serve to attenuate the frequencies believe to be involved as to radiating, locally.
    2CW
  2. #82
    Apr 2004
    Milwaukee,WI
    1,063
    7695
    857
  3. #83
    Virginia
    23,871
    7561
    7505
    Quote Originally Posted by converterking View Post
    The OEM's new specs are here:
    LF Series High Performance AC Filters - Filter Concepts
    Note that below 50 Khz, it attenuate at only about 6 dB.
    I haven't yet had sight of where the P-P is oscillating. Hz-wise.
    NB: It has capacitors in it. I am wary of buying those used, or even NOS, gone "stale", days clocked since first made.
    It might end up no more use than a past-sell-by-date VFD?
  4. #84
    Jun 2001
    St Louis
    17,638
    1712
    2908
    Luckily, the capacitors used in the fiters are not electrolytic, so they do not lose polarization, or go stale..... As a rule they will be film type, and last indefinitely.
    Now, if the unit were a "take-out", a used unit, you would have no particular idea what had happened to it, what might be damaged in such a way as to no longer work. And you probably have no good way to check it.
    The new specs linked by Thermite show 18 dB attenuation for line to ground signals (common mode, typically), which is decent at 50kHz. It will cost a good bit to get more than that. The 6 dB is for differential mode, which may not be very effective at getting through the transformers onto the distribution power line anyway, so the lower attenuation for that mode is not all bad.
    Spec....
    https://www.mouser.com/datasheet/2/8...8bd-184172.pdf
  5. #85
    Jan 2003
    Canada
    11,053
    5026
    3170
    Some good news, turned out the frequency a neighbor was picking up was not from my PP's but from some other piece of electronics not related to me.
    Still running things as is, what will likely happen is when I finally need to get another bigger PP I'll buy the EMI filtering option they can build into it just as an extra precaution then. Until then, it is what it is.
  6. Likes rklopp liked this post
