I’m putting together a small home shop in my detached garage. It has a 100a 220v panel running off the 200a house panel. I already have a 5hp single stage compressor.
My plan is for the 10hp phase perfect pt-330d. I will use a 60a breaker but will run 4awg in pvc conduit surface mount. Where I want the machines is of course in the opposite corner of the panel box. About 50 feet. The 4 awg is in case I ever need to switch to a 70a breaker.
I will be running a Hurco KMB1 5 spindle hp, a bandsaw and a timesaver.
I’m thinking a big knife disconnect switch on the input side of the PP. Then on the output side do I need a 3 phase panel with breakers for all 3 machines? I’ve read on here that many wire direct? Or I could put in twist lock plugs under 50a.
Opinions and why. Thanks and I will have an electrical inspection either way just budgeting right now.
