Greenemachin
- Nov 22, 2017
I have a vintage South Bend Vertical mill i have been trying everywere to find help and no one around here has any knowledge about this type of wiring,Been searching forums here and other places but seems like i have a ODDBALL Motor or something LOL.,
I have all the specs,Pictures and try to supply any information i can BUT,I know nothing about Motor wiring language,I am A Wrench head so i am not scared to try things and get hands dirty thou HEHE
Now to the basics::::
I am new hear so i will get this site figured out also cause i do know my PUTERS also
South Bend Vertical Mill
Tag Says::::
GE Tri-Clad motor (Model 5KC18oDJ208)
PH)1 HP)1 No. PW
Volts 115/230 Amps 13/6.5
Cycles 60 Rpm 1725 service factor 1.25
Time rating Cont. FRAME 180x Type KC
Code K Conn. Diag. 732A640
No wiring diagram on motor or under any plates this is all i can come up with. I will post pictures now,
I want to let you know I have paired up the wires with tape as i checked them with OHMs meter. Wires are all marked with metal tab with only a# on them 2-8 and there is one wire not labeled which i assume is # 1
I want to wire this up as 220
line in will be 2 hots and a ground
Tag Says::::
PH)1 HP)1 No. PW
