Hello,
I recently bought an Atlas Colchester lathe that was a basket case.
It has a Leeson motor (cat# 100956.00, model# C4C17FBA).
The motor has 6 wire leads labeled: T1, T2, T3, T4, T5, T8
For low volt (I assume 110AC):
CCW L1: T1, T3, T8 L2: T2, T4, T5
CW L1: T1, T3, T5 L2: T2, T4, T8
The Drum Switch is a Furnas A-14/A14. It is a 3 position switch with Off in Center position with Forward & Reverse on opposing sides.
On the bottom of the switch there are 6 terminals A, 1, 2 & B, 3, 4.
The switch has been wired where: white to A, none to 1, gray to 2, black to B, green to 3, red to 4.
The internal connections wiring diagram reads:
Forward: A, 1, 2 B, 3, 4
Reverse: A, 1, 4 B, 2, 3
Any help is appreciate but remember you're communicating with the electronics class idiot!
Keep it simple, PLEASE!
If in this posting I made any faux pas, please accept my apologies.
Thank you. Lou
Here are the motor specs:
Catalog No 100956.00 Model C4C17FB4G
Product type AC MOTOR Stock Stock
Description 1/2HP..1725RPM.48.TEFC.115/208-230V.1PH.60HZ.CONT.NOT.40C.1.15SF.RIGID.GENERAL PURPOSE.C4C17FB4G
Information shown is for current motor's design View Outline | View Connection
Engineering Data
Volts 115 Volts 208-230 Volts
F.L. Amps 8 F.L. Amps 3.8-4 F.L. Amps
S. F Amps 8.4 S. F Amps 4.1-4.2 S. F Amps
RPM 1800 Hertz 60
HP 1/2 Duty CONTINUOUS TYPE CF
KW 0.37
Frame 48 Serv. Factor 1.15 Phase 1
Max Amb 40 Design O Code L
Insul Class F Protection NOT Therm.Prot.
Eff 100% 66 Eff 75% PF 61
UL Y-(LEESON UL REC) CSA Yes Bearing OPE 6203
CC Number CE Bearing PE 6203
Load Type Inverter Type NONE Speed Range NONE
Thank you. Lou
Engineering Data
RPM 1800 Hertz 60
KW 0.37
