Rapid_Tech
- Oct 27, 2014
- Toronto
Hey Guys,
I recently purchased a cnc lathe (2003 Gildemeister CTX310). Being a European built machine it requires 400V/50Hz. From everything I've read, the machine will be okay running on 60Hz. Even the shop I bought it from ran it on 60Hz with no problems.
I have 240V at my place but having difficulties finding a 240V to 400V transformer. The transformer I got with the lathe is a 25kva 600V to 400V and I have another 30kva 600V to 240V transformer as well which I'm not using. Would it be possible to use the 600V to 240V in reverse so I get 600V out of it and then feed the power into the other transformer to get it back down to 400V? Other than being slightly inefficient would I have any problems with this setup?
Thanks for any help you can offer.
