Ive used this rpc for some 15 years with few problems. A couple days ago it popped the start caps during heavy use of the air compressor. I found that the ge 6x550 relay contacts stuck. That relay is no longer made replaced with the supco supr.
The problem is when replacing the relay and caps I lost track of the wiring connections, i know dumb ass.
So i believe this is pretty close, the #5 pin out on the relay probably goes to L2?
The r line is the developed leg.
Does this look right?
Thanks jeff
Thanks jeff
