smileypants707
- Feb 20, 2020
I work at a bean-to-bar chocolate factory, and frequently use a vibratory sieve (the cylindrical silver thing on the table):
There is a junction that attaches the vibrator mechanism to the single phase motor:
and is supposed to use three of these [pretty expensive] special rubberized bolts; but those break more often than we prefer (every few months) likely from the torque/ stress of the abrupt start up of the single phase motor.
So instead of using the rubber bolts, we have simply been using zip ties like so:
Which works just fine, but these also break/ need to be replaced about once a month. It is an easy fix, but I got to thinking.. It would be nice to figure out a way to soft start the motor (or use some form of VFD); so that this vibratory mechanism undergoes less stress upon start up. This way we could use the original rubber bolts instead of zip ties, too.
Here are the motor's specs:
115 V | 60 Hz | 4.0 Amps | 3430 RPM | 1/3 HP
And here are some other doo-hickies that look important:
I admittedly know very little about motors/ electronics; but I'd like to try to find a possible solution to this issue so that I can propose it to my employer.
Thank you!
Thank you!
