Don Gitzel
- Jul 25, 2017
What do you think about using potential relays to start a RPC. I found them finicky and troublesome. I usually wire the start relay to the start button momentarily energizing the start relay and releasing the button when the idler comes up to speed. If remotely started, I will use a time delay relay. I think potential relays are more meant for single phase refrigeration loads.
