After finally working out the kinks on a used 20hp rotary phase converter I'm now working on wiring up a 2hp Bridgeport mill and 3hp Victor 1440G lathe. The rotary is in the opposite corner of my shop about 80' away from the machines. I plan to run 4 gauge wire with a 50 amp breaker to the rotary, which is right next to a 100 amp service panel. From there I plan to run 6 gauge wire to a 3 phase load center, which is fairly close to both machines. Each machine will be on its own circuit with a 20 amp breaker going to the mill and a 30 amp breaker going to the lathe. Each machine will be plugged into a twist lock receptacle using 10 gauge wire. The Bridgeport motor apparently draws 5.8 amps at 240V and the lathe 3.4 amps (coolant pump included). Am I on the right track? Suggestions?
