Pro VFD guys, lets figure out this Yaskawa 626VM3
Likes Likes:  0
Results 1 to 6 of 6
    Feb 2014
    UT
    553
    102
    Default Pro VFD guys, lets figure out this Yaskawa 626VM3
    Have a machine we bought knowing there was a spindle drive glitch somewhere. Finally got it under power. Before so the drive was cleaned up and visually inspected but not removed. On power up, the drive seemed healthy as it received 3 phase power. However, it seemed on this machine the DC buss does not get charged up until you initiate all the drives and such. As I attempt to do that, I get an F-A00 alarm which appears to be a charging error. When the drive is initially powered, all boards are powered, parameters ar accessible, etc. All seems to work well, but when it tried to initialize, it doesn't like that.
    Now...... I am already onto 'something' as I discovered the morons before had cross threaded L1 into the drive so though the screw was tight, the terminals certainly were not. There was evidence of arcing there but not severe. However, that could have easily thrown things when under load. I am not sure if a Yaskawa will show a diode problem, resistor, etc, or just say "can't do it".....?
    One would think the loss of L1 would immediately get flagged but I have not been able to even get the DC buss charged. I have the screws tight now and was really thinking I found the issue but now wondering what damage that did. The charge light has never lit for me. so I feel confident when the drive tries to charge, something immediately trips and puts her in limp mode.
    Jun 2001
    St Louis
    17,929
    1841
    3008
    Looking on page 211, there ae several possible causes. The simple one is the inrush resistor, If it fails, the bus will not be charged up to the point that the contactor will close to apply full power. The reistor is to avoid having a huge current pulse when the thing is turned on.
    The resistor charges the drive at a low current up to where it is safe to close the contactor. If it is open, the sequence will not occur, and you will have more-or-less the situation you describe.
    If that is nt it, the other choices all seem to involve replacing the inverter, etc.
    Feb 2014
    UT
    553
    102
    Agreed. Finally got the book and talked with Yaskawa and looks like I need to check all components on the DC buss side. There was some indication the MC contactor, or even a capacitor could be at fault but I guess we will know more soon enough. Going to tear into it today.
    Jun 2001
    St Louis
    17,929
    1841
    3008
    A leaky enough capacitor can cause the resistor to fail to charge up the bus..... But normally, that also fails the resistor in short order, because they are only sized for a quick "hit", wattage wise. If the bus is held down by a leaky cap, the resistor gets over-powered and generally opens.
    Feb 2014
    UT
    553
    102
    Well, the meters are pointing me in a different direction and I have the processor board out of it now. There are no line resistors, just a reactor that is built like a Mack truck. The magnetic contactor has a 200V coil in it that is driven by a small relay module that is fired with 24VDC from the processor board. I verified 24V is present at the relay module and waiting for one side to pull down to 0V to fire. In short, the DC buss magnetic contactor is not even trying because the relay module is not getting power from the processor board.
    And the repairs look deep. I have so far traced the 0V line to a tiny SMD transistor, then back to a Schmitt trigger chip.
    At this point, I need to be very sure the drive is fully "enabled" and such but I would not think I would get a "failed to charge" error if the drive was not trying to charge up. When I hit reset, you hear a small mechanical relay on the main board, not sure what it does, but drive looks normal for 4 sec, then that relay kicks out and the error is produced.
    A PCB layout would sure be helpful!
    I guess the drive was sent to Yaswaka some time back to get repaired. They literally did nothing but repair ONLY two little capacitors that had failed. Only another 5-6 on the board! I will probably just change them all if I am ordering parts but no clue where my issue really is just yet.
    Aug 2018
    INDIA
    9
    Quote Originally Posted by huleo View Post
    Did you solve the issue
    Sent from my Moto G (5) Plus using Tapatalk
