Hello All
I've been running my converted Miller CP200 for some time now and it's been performing well.
Today I decided to remove the side panels and blow out the accumulated dust. So after a through cleaning I decided to take out my multi meter and perform a variety of voltage checks. So it being a three phase transformer with three individual coils I went about testing each coil's AC voltage output. What I found is the center coil which runs through two motor run capacitors was only putting out half the AC voltage of the two outer coils, for example each outer coil tested at approx. 24VAC the center coil showed only approx. 12VAC.
Is this normal and to be expected? Since the center coil is running through the two capacitors? Or should all three coils be testing at approx. the same voltage?
