Hi guys wondering if its ok to start my motor in reverse if its still slowing down? I have a feeling this is probably fine on most newer VFDs but just want to be sure it wont damage my older Mitsubishi Freqrol Z300. See manual here: http://www.vfds.com/manuals/mitsubishi-z300-manual.pdf
Im working on a rigid tapping program for my retrofitted Fadal with Kflop control. I see some people wait for a signal from drive that it has stopped. Just wondering if this is really necessary? I was planning on adding a slight delay and then reversing, but just want to be sure i wont damage anything if i happened to switch it in reverse while its still rotating. Am i overthinking this? Should i just switch forward relay off and reverse relay on right away? Thanks in advance.
