Romi 13-5 460v to 230v
Results 1 to 8 of 8
    May 2021
    Ohio
    Default Romi 13-5 460v to 230v
    just purchased a Romi 13-5 lathe and I can’t for the life you me get it to run on 230v 3 phase. I change the wiring in the Motor to low voltage. What am I missing
    Oct 2005
    22,060
    Quote Originally Posted by Dalt1028 View Post
    The "control wiring" ?
    May 2021
    Ohio
    Please explain. I’m very new to all of this.
    Oct 2005
    22,060
    You have push buttons and contactors on this lathe ?
    Nov 2019
    CANADA
    Ontario
    643
    1015
    154
    find an electrician....
  6. Likes digger doug liked this post
    Aug 2017
    Connecticut
    80
    18
    Assuming the control voltage is 110, you need to rewire the main motor, and the coolant pump motor if any, rewire the control transformer for the proper incoming voltage, and adjust or replace the motor overloads for the proper current. Also, some lathe controls like the LeBlond servo shift controls are phase sensitive and won't work properly if wired out of phase (direction of rotation wrong).
    Nov 2002
    Burlington, NJ
    1,435
    38
    174
    What swarfmeister said. I used to install these machines and from memory I'm pretty sure there is a control transformer. If that is not rewired it will only put out about 60VAC, not enough to pull the motor contactors in. Also the overloads will need to be doubled in size or they will keep tripping out. I think the coolant pump is 3 phase as well, rewire that for 230V.
    Mr Bridgeport
  9. #8
    Feb 2007
    Montana
    1,154
    12
    125
    Try over at garagejournal... some very knowledgeable and patient folks over there.
