rule308x
- Apr 20, 2012
- USA, Near Nashville Tennessee
Hello,
My 15 hp rotary phase converter, which has been working fine for months, is having a problem. I don't have the schematic and did not build the unit and am looking for help diagnosing and fixing the problem. It is wired to a 220v 60 amp breaker and has been powering a 6.75 hp nardini lathe. When it is switched on the idler motor comes up to speed quickly and quietly and stays running. When a load is applied (lathe turned on) the contactor sputters and arcs (see video).
I'm not an electrician but I can use a multimeter. I've pictured the box and the major components below. I can provide more pics and information if that will clarify.
I would be grateful for any help diagnosing the problem or suggestions for fixing the problem. I'd be willing to replace the automatic components with manual switches if necessary.
Jeff
Jeff
