Nemesis
- Nov 7, 2015
- Southwest, MN
I recently picked up a Monarch 12CK lathe that I need to power. This is the first of several 3 phase machines I will most likely end up with over the next several years. I will not be able to actually dig into the lathe for a year or so as I am in the process of listing our house and moving, but am preparing for my shop at the next place. I have been looking at Rotary Phase Converters and reading a ton of information here on PM. I have two options in front of me right now and am trying to decide if either of these is a good option or if I should keep looking.
The first is a 12 year old, supposedly lightly used Ronk ROTO-CON 2D-1. According to the plates on it, it is there 28KVA model for a 25HP 3 phase motor which makes me believe it is probably a 50hp idler? It requires a 120 amp 1 phase input. I realize that this is completely overkill for my uses and that cost for idle time will be higher, but the price is less than a new basic 10hp RPC and it provides the ability to power any machine I would ever end up with. Other than idle cost and I assume more noise, are there any other issues with running a RPC this big with such a relatively small load? Also, it appears to simply have the starter and run capacitors in the control box but none of the relays and other additional components of the newer ones. Is this an issue?
Another option I have is a buddy of mine has 4 new old stock 25HP 3 phase motors sitting in crates and I can basically have one. I am looking at possibly purchasing a pre-made panel from either American Rotary or North America Phase Converters and going that route. The problem is the RPM listed on the motor plate of these motors appears to be much lower than what both companies require. I have a picture of the plate below. Any thoughts on using one of these motors with a pre-made panel? I have emailed both companies with a picture of the plate as well, but have not heard back from either one yet.
Thank you for your help!
