I am using a 10 HP rotary converter that is providing pass-thru voltage of about 240V on two legs, and something on the order of 265V on the generated leg. This is a commercial converter that I acquired along with a Tree J325 CNC knee mill.
The Tree input power spec is 230V +/- 5%, and I have run into a power-up problem (servos won't turn on) on the machine that may have been caused over time by the use of this converter, by previous owner and then me. The Tree employs a shunt-trip input breaker for the 3-phase power, and it now trips immediately upon application of power to the servo cabinet. Not a promising sign, in my estimation. The control unit is powered separately by the two 240V legs, and doesn't show any issues.
I want to get my power situation squared away before I resume troubleshooting the Tree problem. My questions are these:
-- What should I look for in the converter setup to reduce the voltage of the generated leg?
-- OR, will a 3-phase transformer that is fed with unbalanced voltages from the RPC provide any averaging function to help the individual legs get closer to each other?
