RPC- Ready made, panel, or kit? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21
    Dec 2008
    IL/WI border
    3,183
    1001
    922
    Visit a motor repair store. I got my 15HP monster for something like $150. Make sure you buy low RPM one: they're MUCH less noisy. Mine is like 1200 rpm, and I need to come closer to hear it's running (I put it indoors outside of the shop anyway).
    And although I'm perfectly capable to build a panel, I chose to buy one. Sourcing of components and buying them from different sellers would be almost as expensive (if not more) or very bothersome and time consuming.
    It was a small engineering NJ company I found on eBay. They made some no charge changes to their regular setup to better fit my particular motor (larger capacitors?). All I added to the panel later was an LED showing when the unit was ON (an RPC with a faster motor wouldn't need it unless I were deaf ).
  2. #22
    Jan 2018
    South Carolina
    181
    83
    I need to get a motor pretty cheap to make it worth my while. I'd rather spend $800 on a brand new purpose-built RPC than piece one together for $600. If I can't get a motor for less than about $200, I'll just buy a complete unit. I'll call some motor places to see what they've got.
  3. #23
    Dec 2008
    IL/WI border
    3,183
    1001
    922
    Here is the the company I bought my RPC panel from: WNY Supply & Phase Converter Store :: Rotary Phase converter panel
    P.S. Apparently, I made a mistake about their location. WNY Supply was not from NJ. They're in NY.
  4. #24
    Virginia
    26,146
    7561
    8245
    Quote Originally Posted by MichaelP View Post
    More pressed for time, yet, I HAD all the components at least three times over from HVAC and "quiet elevator" experiments (DC Drive thing...).
    Except a suitable enclosure.
    With holes in all the right places.
    Jim Gorman had done all that. Then improved on it. And more than once.
    so.... I bought a last-revision "large box" Phase-Craft..... and put the time saved towards other forms of outright waste and general procrastination that was at least less boooooorrrring.
  5. #25
    Jan 2011
    New Brunswick, Canada
    1,585
    1916
    618
    I also bought a 10 HP panel from them, and it's been working flawlessly for about 4 years now. Mind you, I work as a hobbyist...
    Brian
  6. #26
    Jan 2011
    BFE Nevada/San Marcos Tx
    1,046
    915
    545
    Quote Originally Posted by MushCreek View Post
    Scrap yard will charge you between .30c and .60c per pound for a used motor, no guarantee it works, that is why you need to ohm windings to check it out. Avoid motors that were brought in individually (unless still new on factory pallet) as they tend to be pullouts with problems, look for whole machines with motors still attached, they tend to be good, but you still need to check windings.
  7. #27
    Mar 2019
    North Carolina
    22
    23
    Sachmanram and MichaelP:
    I am looking at panels offered by WNY Supply to go with a 15HP motor I picked up at the scrap yard today for $87. I see that WNY Supply sells a "Standard" panel and a "Gold" panel, which apparently has additional overload protection and has three banks of run capacitors.
    15Hp Gold series rotary phase converter control panel
    Did you get the "Standard" panel? I'm wondering if it is worth spending ~40% extra for the "Gold" panel. It might be overkill in my case for a 1980's era manual lathe.
  8. #28
    Jun 2001
    St Louis
    17,844
    1788
    2970
    I already had the parts, w/o enclosure, including the motor.
    Then I found a used good old RPC for cheap. Bought it, and wired it in, and it has been working ever since. I still have the parts, dunno what I;ll do with them. The machine is an Arco and it just plain works, and has done for 10 years. My input to it was tightening screws and some RTV to eliminate the rattles, plus a little static balancing of the rotor, which had had a fin broken off it, causing vibration.
    The deal with a good factory RPC, especially older ones, is that the motors were made to be an RPC, so they tend to be lower impedance. You do not find that with stock factory motors, and it can make a difference in how the thing handles flipping the lever to reverse. In my case, I can "plug reverse" no issue, fast smooth reverse with no drama.
    Mine also, because it was factory made for the purpose holds up voltage well, and has very few parts.
    The kit units are probably OK, but build quality varies, and they tend to be made for a HP range, not for "that" motor. If you oversize enough, the difference is not much, that I will agree with. In your present case, a 10 HP idler would need only some method for starting it, it would not need any tuning, and tuning might be counterproductive.. If you connect a 5 HP motor, that might change.
    The noce thing about used RPBs of good quality is that they are simple, the "special sauce" is usually in the motor, and motors are very long-lived if given half a chance to work.
  9. #29
    Jan 2011
    1,585
    1916
    618
    Quote Originally Posted by 4kinetic View Post
    Kinetic,
    I bought the Standard panel, and it works just fine...
    Brian
  10. Likes 4kinetic liked this post
  11. #30
    Dec 2008
    IL/WI border
    3,183
    1001
    922
    Mine is the Standard version too (I don't think they even had the Gold ones back then).
  12. Likes 4kinetic liked this post
  13. #31
    Feb 2004
    peekskill, NY
    24,222
    4415
    [QUOTE=MushCreek;3389750]How do you power tap with a VFD?
    It can be done. Plug reversing motors on three phase power is one reason I do keep a rotary
    converter in use in my home shop.
    However at work I have utility three phase available, how do I power tap? With a procunier
    tapping head on a drill press driven by a (single phase power driven) VFD.
    Just sayin.
