The wire is hot...
I have a RPC, and I smelled something burning, turned out to be one of the run capacitors wire was melting, its one of 12 capacitors in a series. Is this capacitor bad and need replacing or is something else causing this. It hadnt been running but 10 mins or so.
Heh heh...
Troubleshooting is so much fun!
So I see he's already figured it out, but I'll throw in my two cents' worth...
When troubleshooting, look at the symptom without prejudice.... meaning...
The wire is melting because it is hot. Now, take it from there... the next clue, is that the wire is hot.
I had a guy with a locomotive... not a passenger, but a work-train... and a certain fuse kept blowing on one of the traction inverter systems... it had two (one for each end), and only the one end would blow. He had the truck (bogey) with the motors rebuilt... changed the trucks, changed all the GTO's (yep, older), all the snubber caps... damned near everything... just kept blowing... The drive tech support group, engineers, and their best techs fought it for months... then they gave up and parked it...and there it sat.
I had a few spare hours in my training schedule, so I checked it out. I shut the power down, removed the fuseholder, cleaned the wiring connections TO the holder, reinstalled it on rubber isolators, put it back on, and sent it out to a test track in the middle of the night, worked perfectly.
Problem is, the fuseholder backplane (insulator) was affixed to a framework mounted rigid to the railcar chassis... in an area under the bolster. Well, they used this particular locomotive to pull a small platform-type spot-tamper that had a 1,000 gallon water tank and sprayer, and they'd pull it out to a work area, and run the tamper with it coupled to the locomotive, 'cause the tamper was small, it'd jump around. Of course, the tank had 8000lbs of water in it when they started, but they'd run out of water after running the sprayers for 5 hours 'cause the sprayer nozzles had been removed 'cause they'd always clog up with dust because the filter screens were gone from the strainer. So they'd run the last 3 hours with no water, which made everything really dusty... and of course, when they got back, they'd run the whole works through the car-wash to get all the dust off, particularly the end bolster facing the tamper. Did I mention that the sprayer's pipes soaked the bolster down well too? Having it come out as a flood, rather than mist, the tamper splashed crud all up under the bolster, onto the traction motors, n' stuff, hence their reasoning that the motors needed a rebuild.
So two things were happening: First, the connections were getting a daily bath of iron rail dust, nasty water, and ballast dust... THEN they were hitting the fuse panel that was feeding the inverter with a pounding from the (now rather light) spot tamper bangin' on the coupler about two inches away.
The bad connection made the fuse a bit too warm, and the tamping vibration finished it off.
