Is the slight forward and aft movement of the shaft a normal movement of this Delco, single phase, 1.5 HP repulsion induction motor?
I just picked it up locally that was on a working air compressor, according to the seller.
I'm going to tear it down for a general cleanup and possible bearing replacement, just curious if I should try to eliminate the movement of the shaft or regard it as normal??
Thank you
Delco 1.5 HP induction on Vimeo
Thank you
