TheMetrologist
- Jan 20, 2020
I have owned a Hitachi Scroll compressor since 2013 that was originally hooked up to 3-phase 208 at my old lab.
Currently I am moving the unit to a new location where 3 Phase is not supplied nor is it affordable to have run.
So I need a way to convert single phase over to 3-phase power.
What is a cost effective and quiet way of doing this? (I can build an enclosure if I absolutely have to...)
Can you please provide a link to a specific unit that would work? I need something that will last a long time.
This compressor runs for 5 minutes and rests for 10-15 min then runs for 5 min when in use. It is setup with a 250 Gallon receiver tank.
I have your standard 110 and 240 single phase outlets at the new location.
This unit requires 208 or 230 3-Phase at 60Hz to operate.
So I need something that will convert single phase 240V to 3 Phase 208 or 230 (208 preferred as that is what the unit was on)
The quieter and more affordable the better.
UNIT SPECS
Hitachi Scroll oilless air compressor, power
230/3/60, air cooled, 120psig, rated for 21.2 CFM
Model SRL-5.5M6L
FULL MANUAL OF UNIT (Link)
https://service.relevantsolutions.c...L Instruction Manual - Three Phase 060109.pdf
UNIT SPECS
Model SRL-5.5M6L
