RHammer9
- Jan 2, 2021
- Outside Bellingham, WA U.S.A.
After lurking for a while (I believe that is a required first sentence isn't it?) I finally made an account and am seeking some of the accumulated knowledge around here.
I just bought a Tree Journeyman 310 with Dynopath Delta 10 control. I have minimal expierence with milling or CAM software , and modest expierence with CAD. I imagine I will become a much more active forum member in the near future.
First off I would like to get the machine up and running. Looking the machine over, it looks as though the spindle drive motor is the only part of the machine requiring 3 phase power. a single phase conversion would involve little more than a new spindle drive motor, some rearranging of electronics running off the third leg, and just a little wiring. (The coolant pump may have been three phase. I can't remember for sure, but it's an easy fix.) There was no spec tag on the motor so I pulled it last night to bring it into work for testing. (three phase available) I can get RPM, amp draw, wattage, and ultimately HP output from that. A little preemptive web search has indicated a shortage of long shaft single phase motors though. I would really like to hear anything known about the reason there are so few, any known sources worth checking out, if people would reccomend just buying a VFD and putting the 3 phase motor back on, or another option I haven't considered.
The shop that I have the machine in has a lower than average power feed where the total amp draw has to be kept in mind. I would share more specific information if I had it, but haven't checked the line in voltage, nor do I know the feed line size. I do know that there were many things done on the property years ago that were done quickly without much thought of future needs .
Any assistance that you have time to share would be greatly appreciated. If there is more information that I can give, just ask and I will gladly do what I can.
(Sorry, this grew longer than intended, and again if I am inadvertently missing any forum etiquette)
