LowEnergyParticle
Cast Iron
- Jul 26, 2004
- Beaumont, near Houston
Generally, VFDs that allow single-phase input require de-rating the power controlled by the VFD to a value specified by the manufacturer which I've seen quoted between 50% to 66% of nameplate. In short, your 10 HP rated VFD shouldn't be hooked up to a motor larger that between 5 HP and 6.6 HP (which you can't find anyway!) depending on the manufacturer's de-rating spec.
The de-rating is necessary because the bridge diodes in the input section aren't sized large enough to put the entire load through: a full-wave bridge for single-phase uses only 4 of the 6 diodes provided for the normal 3-phase input. Also, the smoothing capacitors would be sized too small.
So, my thought is to add an external full-wave bridge sized to handle the max output rating of the VFD. Additional smoothing capacitance can be calculated and added externally. This new external input section would be wired into the VFD across the DC bus. The remaining issue is the phase-loss circuitry. I've seen several (older) VFDs where the phase-loss circuits were CTs clamped on the input phases and no discrimination was done in terms of timing checks to make certain that 3 actual phases were present. So, the CTs could be moved over to the new input section and one input doubled up with 2 CTs on it and the other input monitored by the remaining CT.
Does this seem like a workable scheme?
Thanks!
Dave
Thanks!
Dave
