Hi guys, I have a new to me Chinese Bridgeport that I just purchased at auction. The listing said the machine had been tested and worked as it should. It has a 1.5hp three phase motor so I connected a 3hp VFD straight to the original power cable. The coolant pump, light and power feed all work but when I try to run the motor a relay in the control box rapidly engages and disengages like its fluttering. There is a small square button on the relay which manually engages it and if I hold the button in then the motor runs beautifully but if I release the button then the motor stops again. There is a second identical relay next to the first and it does the same fluttering but I don’t know what it powers as when I hold its button in all I get is a whirring sound deep in the base of the machine. Maybe the coolant pump? So, what is causing both the relays to flutter and how do I fix it. Why would a VFD cause the fluttering? If I can fix the fluttering then everything will work as it should and I’ll be as happy as a pig in sh!t. Some info that may help: This is the third VFD I have installed and they are all the same brand and rating. The other two were plug and play and then I made adjustments to the ramp up, ramp down etc and they are working well. The mill was built in 1999 and to Australian electrical standard. We only have 230 volt single phase and 420 volt three phase. The relays are Siemens 3TB40 22-OX. One other thing I noted is the the variable speed control on the power feed doesn’t change the speed a great deal. I thought it should slow the speed of the table to almost zero. I notice the newer mills like mine are single phase now. Of course any ideas or help would be greatly appreciated. Cheers Stuart.
