oughtsix
- Sep 1, 2009
- oregon USA
I had a friend complain about the external speed control potentiometer only making speed adjustments through about a third of the range of the potentiometer.
After a little thinking I came up with this:
I just had a bit of inspiration re the speed adjustment issue with the potentiometer. There are two basic configurations for potentiometers: Audio taper and Linear taper. With linear taper pots the resistance is directly proportional to position of the pot. With an Audio taper pot the resistance is some function of a curve (very slow change at the beginning of the range and very fast change at the end of the range). From what you described it sounds exactly like you have an Audio taper potentiometer. I think if you swap your pot for a Linear taper pot you will get the speed control you are expecting.
FYI.
FYI.
