Strostkovy
Titanium
- Oct 29, 2017
So I have the guts to a 10HP RPC I bought at an auction and integrated a lot of part into my larger RPC. The issue is that the potential relay they used is undersized and I would like to add a contactor to have it switch the capacitors indirectly.
I found I have no contactors that are suitable but I have a ton of 50A SSRs (Still have to check the capacitors to make sure they don't pass more than 50A), which would generally be no good for switching capacitors due to the massive surge load capacitors imply, but these only switch on when the voltage crosses 0, and only turn off when the current crosses 0. I can't think of any combination of on/off timing or capacitor voltage that could result in excessive voltage or surge current.
Does anybody see any issue with doing this? Biggest downside is I have to have low voltage control power, so the extra inconvenience may negate the convenience of having all parts on hand, but I figured even if I don't go through with it this way this might be an interesting topic for anyone who wants to switch out/in balancing capacitors in their RPC.
