JasonPAtkins
Hot Rolled
- Sep 30, 2010
- Guinea-Bissau, West Africa
Hey all, not a VFD or transformer question, but these seems to be where the sparkies are, so...
I have a Marathon 6hp 1ph motor that I think was bought at TSC and is being used on an air compressor that originally had a 5hp motor.
A cap went bad, and someone else opened it up, disconnecting the jumpers. I have a replacement cap (I'm pretty sure) and a wiring diagram, but can't figure out which terminals on the caps are what.
They're combo start/run caps, which I would've said was from some other motor, but lo and behold, the diagram does show a pair of caps with three legs each.
(the two caps to the right of the motor in the diagram)
(closer, I hate how the forum smashes images so small)
So the question is, the terminals on the cap are labeled as "C", "FAN", and "HERM". Which is which? Further complicating the situation, the top cap in the drawing has two connections coming out of the flat side (can't remember the names for the two sides of a cap, sorry) while the lower cap has one on the flat side and two on the curved side.
So essentially, there are two jumpers that tie two terminals of one cap to two terminals of the other, leaving a yellow wire on the 3rd terminal of one cap and brown wire on the unoccupied terminal of the other - but I don't know which terminals the jumpers should connect, or which those brown/yellow wires should grab. My problem would be solved if the cap legs in the diagram were labeled like the ones on the physical caps, but they're not.
Any guidance?
Any guidance?
