jaddy
- Sep 8, 2013
- misssissippi
I have a arco hd25 hp RPC when i power the unit up, it comes up full speed within about 5 sec, but it making a humming noise. there is an electric contactor that stays engaged when the rpc is up an running, which i think it is suppose to cut off, when up to full speed. I thought it was the relay, so i replaced it, not the same brand but the same diagram on the side. The problem still exist, the relay is hooked up the same way the other one was 1, 2 and5. but not 100% sure if correct.
Inside the panel of rpc is 2 starting caps, a series of run caps, relay and contactor.
I thought sure it was the relay but now im left scratching my head. Voltage on 3rd leg is 276 which i thought was high. Any help will be appreciated
