ancientbrass
- Apr 30, 2016
Good morning, colleagues!
I'm in the process of revamping the wiring on an old eastern European multi-purpose mill/lathe/shaper, while maintaining the original control hardware (because it's robust and convenient). I'm in a one-person owner-operator shop.
Situation is this: I have a VFD that can run 2- or 3-wire control, but there's no means to obtain FWD/REV/STOP(RESET) without control logic. (The FWD and REV controls are momentary NO, STOP is NC; VFD expects a fwd/rev switch and not separate FWD and REV run signals)
I am thinking to add a simple relay circuit to manage control, and then operate the VFD in 2-wire mode. FWD would trigger a holding relay, which triggers RUN on the VFD, and REV triggers RUN + a hold on REV.
My questions: (1) is this reasonable and (2) would low-impedance reed relays be a good choice for this job?
Edit: I would ideally like to supply voltage to the relays directly from the VFD control terminals, rather than using an external power supply.
