teco 1hp 230v VFD starts backwards and slow
Results 1 to 15 of 15
    Apr 2007
    cincinnati, ohio
    85
    7
    Default teco 1hp 230v VFD starts backwards and slow
    Hi gentlemen
    I have an older Teco 1hp VFD 230 single phase to 230v three phase VFD. I had been using this VFD with a 3/4 horse motor with no problems. I upgraded to a 1 hp motor and I have a problem that I can't figure out and don't understand. When I attempt to start the motor at any frequency, it turns slowly in the wrong direction most of the time. Sometimes but rarely it will start and come up to speed in the correct or reverse direction. I have looked at all settings and can not solve the problem. Can you make any recommendations please so it will start in the correct direction as it used to when connected to the 3/4 hp motor? Both of the motors are GE 3 phase motors and are wired correctly. I have tried re-arranging all three phase lines with no change in the outcome. The only item I changed was the motor. When it does start up and run at the correct speed it performs properly, a variable speed, sufficient power no weird noises and no smoke escaping.
    Here is what the unit is
    1 HP, 230 Volts, 1 Phase, IP 20, Teco, JNEV-201-H1 MODEL #: JNEV-201-H1
    230 Volts 1 Phase Input, 230 Volts 3 Phase Output
    Bill
    Jun 2012
    Eastern PA
    845
    188
    348
    Bill:
    If you swap any 2 of the phases at the output of the VFD(or at the motor) the direction should be reversed.
  3. Likes Steven-Canada liked this post
    Oct 2012
    Iowa
    303
    141
    77
    There is a programing parameter in the VFD for motor size, is this set to 1HP?
    Running slow, are you sure the motor is not wired for 440VAC operation?
    Jul 2014
    MI USA
    816
    193
    341
    Post the nameplate tag of the motor.
    Is the motor starting unloaded?
    What is the motor's load?
    SAF Ω
    Jun 2001
    St Louis
    17,478
    1621
    2803
    Starting poorly suggests that one phase wire is not reliably connected, or the motor has an issue, or the VFD has an issue...
    A 3 phase motor should start easily and in the same direction every time. If it does not, it is either not getting 3 phase, one of its wires is not connected, or it has an internal problem.
    Many 1 HP motors have a thermal protector. Those things are not immortal, they can go bad. Could be the case. An ohmmeter check should give an answer to that question.
    My very first check would be to try that VFD with another motor. If it runs the other motor OK, then the one you are now trying to use is suspect.
    Mar 2009
    4,544
    82
    805
    Auto tune with the 1hp motor. While doing this chant "Teco is not cheapo" while sitting in the Lotus position.
    Aug 2004
    San Ramon, CA USA
    2,598
    23
    568
    Quote Originally Posted by JST View Post
    Most failures inside of the VFD that might cause this would be showing up as a fault code. I like the idea of a bad connection or a thermal protector in the motor that is not working right. That would explain why it sometimes runs correctly. When you get a partial connection on one phase inside of the motor, it can spin in somewhat random directions.
  9. #8
    Apr 2007
    cincinnati, ohio
    85
    7
    Quote Originally Posted by awander View Post
    Bill:
    Ok but the problem is that it is running slow like 50 rpm
  10. #9
    Aug 2004
    San Ramon, CA USA
    2,598
    23
    568
    Hook the drive back up to the old motor. If it runs that motor fine, it's the motor or wiring.
    Re: Autotuning: normally I would agree with that approach, but that particular Teco drive is basically a V/Hz drive with an automatic voltage boost at low speeds, it's not really a Sensorless Vector Drive (even though they say so). There is no tuning parameter for it, which is how you can tell...
  11. #10
    Apr 2007
    cincinnati, ohio
    85
    7
    Quote Originally Posted by ignator View Post
    yes Motor is wired for 220 not 440
  12. #11
    Oct 2017
    393
    106
    99
    That sounds exactly like a three phase motor trying to start on single phase or with a very weak third leg.
    Disconnect one leg and briefly run the motor (be sure to isolate that wire, it will still develop a nasty voltage). Do that with each leg. I suspect once you will see no change in behavior and twice you will see no motor movement at all, or very, very little.
    If the above is true, wire the VFD back to the old motor. If the old motor works fine, then the VFD is fine and your other motor is wired wrong or burnt out.
  13. #12
    Mar 2009
    4,544
    82
    805
    Or the drive cannot handle a 1 hp motor. Even though the manual or drive name plate says 1Hp. Doesn't make it so on a ChiComm product.
  14. #13
    Aug 2004
    San Ramon, CA USA
    2,598
    23
    568
    Quote Originally Posted by rons View Post
    But that would not make it try to spin the wrong direction...
  15. #14
    Mar 2009
    4,544
    82
    805
    Quote Originally Posted by Jraef View Post
    You can't be sure what the feedback loop/recovery software is doing.
  16. #15
    Apr 2007
    cincinnati, ohio
    85
    7
    I wanted to thank everyone for their input. This caused me to take another look at all the possible settings in the VFD. I didn't think that it would be that different with the 1/4 hp increase but evidently, it did. I updated the settings from F43 to F50 and that has solved the problem. It now starts good and runs great. It even starts at slow, mid and high RPMs forward and reverse. There were some good suggestions and ideas that I hadn't thought about. Again Thanks
