Darren McCarley
Cast Iron
- Nov 24, 2017
- DFW
So I bought a Teco L510-202-H1-U and have everything wired up. (220v 1ph to 220v 3ph). Checked and double checked everything.
220v from a good known source (runs mig and tig welders perfectly. One at a time.)
I have a simple Square D wall switch with breakers as my main switch. (Lowes, if it matters)
Power is getting to the T1 and T3 lugs of the VFD, about 105v, per)
The issue I have is the VFD is showing no signs of life. LEDs aren't coming on, fan isn't turning (assuming it is always on), etc
It's as if there's a built in on/off switch I don't know about.
Note:To my knowledge the VFD is new.
Power in:
One leg of 220v to T1
The other to T3
Ground to ground.
This should "just work", right?
Any suggestions?
Thanks in advance.
Darren
Power in:
The other to T3
Ground to ground.
Any suggestions?
Thanks in advance.
Darren
