EtienneNavaar
- Sep 27, 2011
- BC in Canada
I am having difficulty getting my jog button to work on my lathe with Teco JNEV VFD. It is a momentary switch and I have the input connected to the VFD and it is programmed for "JOG" according to the manual. When I hit the button, the frequency displayed changes to 5, which is the default frequency for JOG mode, however the lathe doesn't start. Yes, it will start and run at 5 Hz, I have verified that. If I start the lathe with the start/stop/reverse switch and then hit the JOG button while it is running then the speed with change and reflect the 5 Hz as programmed in JOG mode.
Any help at this point would be much appreciated and thank you in advance to those who reply.
