I bought a 3-phase lathe which came with a TECO FM100-203-N1 (3hp) VFD. It worked fine when I purchased it and I disconnected it from the lathe and transported the lathe and the VFD home. Fast forward two years and I decided to use the VFD for a large 3 phase drill press and Bridgeport mill. It was already wired for the 220V input to L1, L2, and L3. I connected T1, T2 and T3 to a 30 amp plug (NEMA L14-30R) so I could just plug either the drill or the mill into it as needed. I ran the ground from the plug to the ground terminal in the TECO. When I throw the breaker the TECO fan comes on and the frequency is displayed but it flashes on and off (the screen frequency display) in one second intervals. IF I turn the "Freq Adj" knob it changes, but if I push the arrow up or arrow down key it gives an error (I can't say exactly which error as some of the LED light segments appear to be burned out. It looks like maybe Err1 or Err3. I am attaching the video of the behavior.
I am curious whether anyone knows what might be wrong. I get no voltage reading from T1, T2, or T3. I am wondering if that is an issue. It seems like there should be voltage output. Any assistance appreciated. I don't know how else to test this unit.
