Wanting to build another RPC, and it would be a much neater job if
the voltage sensing relay was mounted in a socket.
I haven't seen one in my searching.
Omron makes octal base, voltage sensing relays; the LG2-AB should be the right series.
But they are very proud of them, they run around $200.
ANY relay is a voltage sensing relay, once you've determined what it's pull-in current requirement is... just add appropriate resistance to it, such that it doesn't reach pull-in strength until your setpoint.
On my self-starting RPC, I used an ordinary light dimmer as an adjustable, in series with a smallish contactor... and adjusted the light dimmer 'till the contactor pulled in at a desired point.
Only thing to remember, is that there's a fundamental difference between a relay and a contactor:
A relay is a device which pulls in, once coil current reaches a high enough point for it's magnetism to pull in the contact bar. The relay coil draws a constant current, regardless of wether it is dropped out, or pulled in.
A CONTACTOR, is a special relay who's electromagnet pulls in the contact bar, and once seated, the contact bar becomes a magnetic shunt integral to the electromagnet's polepieces. The result is that it has substantially greater 'holding' force, than 'pull in' force. Once pulled in, the shorting bar's contact increases the inductive reactance of the COIL, which reduces the coil's current substantially. As a result, a contactor flows substantially less current once pulled in, than when it is PULLING in... and the other side effect, is that it will HOLD itself in until a much lower voltage, than what was required to PULL in.
So if you're messing around with relays and contactors to make this work (on a much more sensible budget than a specialty solution) you'll know why it does what it does, right?
What I know about magnetics is that there must be auxiliary controls to get reliable switching control. The reason for this is that in the open gap condition, the pull is strongly influenced by small mechanical variations. In order to over come these problems, a control needs to have sharp switching points that are best done with Zener diodes and associated circuits.
Notice
