TravisR100
Cast Iron
- Aug 7, 2006
- Houston, TX
Not sure if this is the appropriate forum. If not feel free to move.
I understand that power = torque x speed.
But what determines a machines ability to take a particular cut? Is it torque or power?
In reading about VFD’s and induction motors, i think that at 60 hz (on a motor rated for 60 hz) a motor delivers its rated power. As frequency is decreased below 60 speed is decreased, torque remains constant, therefore power decreases. As frequency is increased above 60 hz, speed increases, torque decreases, and power remains constant?
If what is required to make a particular cut is power instead of torque, it would reason that slowing the speed/frequency would reduce the cutting capability. Is this correct when speaking of an induction motor on a VFD.
And how does this compare to reducing the speed of a servo motor? Does a HP rated servo motor deliver constant power throughout its speed range?
I see servos generally have a peak and RMS torque curve vs speed. But not sure how power would plot on that graph.
Why don’t induction motors have similar graphs?
I’m just doing some comparisons of induction motors vs servos.
