Toshiba VF-S15 VFD help
Likes Likes:  0
Results 1 to 5 of 5
    Oct 2020
    AUSTRALIA
    18
    Default Toshiba VF-S15 VFD help
    Hi guys.
    I have just connected a Toshiba S-15 VFD to my Mill which works great but.
    The Mill has 2 x built in Momentary switches, 1 to turn on and one to turn off.
    I would like to hook them up to the VFD so i can use them to start and stop the Mill but i cannot work out which terminals to
    wire them up to and which setting to change.
    can anyone help me with this?
    Dec 2008
    Vt USA
    8,901
    1477
    3154
    I have had very good results looking for operation literature for the several TOSVERT series Toshiba drives I have installed in my shop. Type " Toshiba S-15 manual" into your search engine and see what returns you get.
    The connections for momentary switches will be right on the control terminal block
    Oct 2020
    AUSTRALIA
    18
    I do have the manual but i can't seem to understand or see which relates to using external momentary switches..
    I have used Allen and bradley vfd's in the past which where easy to understand but the Toshiba seems to be a lot more technical.
    Dec 2019
    NEW ZEALAND
    271
    59
    https://www.toshibadrivesandmotors.c...-IO-Manual.pdf
    Page G-3. "3-wire operation (one-push operation)".
    It looks like you want F-110 = 6.
    Oct 2020
    AUSTRALIA
    18
    Quote Originally Posted by SomeoneSomewhere View Post
    Thank you so much.. I would have never found that..
    I will give ut a try tomorrow..
