transformer - 220/3 to 380/3 60hz to run 360/3 50hz ?
Results 1 to 4 of 4
    Jul 2004
    N. GA- 33.992N , -83.72W usa
    4,093
    114
    986
    Default transformer - 220/3 to 380/3 60hz to run 360/3 50hz ?
    i've posted a bit about a euro machine i'm powering . the lathe motor is
    8.5 KW ,50hz, so does the 50 cycle increase the current draw? or will it
    just use what it needs. and what would be the duty margin? 10-12-15 kw?
    i'm new to non- standard power- i've 3ph 220 for years.
    i'm not sure , so i don't need a fire!
    Jul 2007
    UNITED KINGDOM
    5,513
    3473
    2854
    Apart from any change due to increased mechanical load from the speed change (negligible), the motor will just take what it needs. 10kVA is perfectly adequate for an 8.5kW motor.
  3. Likes tnmgcarbide liked this post
    Jul 2004
    4,093
    114
    986
    thanks. i supposed so , but i just needed confirmation on the power
    i asked about.
    Mark Rand , thank you for your insight.
    cheers
    Jan 2005
    The Netherlands
    6,833
    378
    2030
    European machine ??? 360volt 3phases ????
    Look carefully Probably 380 volts 3ph
    A better choise would be to use a 415volts-3ph transformer for tha 50 Hz motor to run on 60Hz
    That 380volts 50hz motor is physiccaly the same as a 415Volts 60 Hz motor
    Peter
