I have a cnc lathe that requires 460v it's a 6kw rated machine 3 phase , my question is I have a transformer here I could use but is a 460 primary to 230 secondary .
From what I can understand some people are saying it can be wired up to work if I connect the 230v 3phase to the output wye side and use the primary delta side for my 460V .
Another question is an isolation transformer a better choice for cnc or is a auto transformer ok as well
Delta supply into Wye windings? Meahhh... It can be
made to work, yes.
Even so, I'd want a 12 KVA or so transformer to do a 6 KVA load with, though. You don't just have to RUN that machine. You also have to be able to START its main load(s), and not just the one-time, but "cycle-wise".
Autotransformers? They CAN make decent economic sense ... up to about 20% - 30% change, buck OR boost. Above that - and at 1:2 you are waaay above it - you are usually better served with full-isolation economically as well as "technically".
That's partly because in larger capacity, full-isolation are more widely used, more common as take-outs from user/business changes, ergo less costly, bought used-but-good.
Example?
There's a 15 KVA 2XX:4XX R.E. Uptegraf Delta-Delta sitting on my lower driveway awaiting a trailer ride to the recycler as would do yah.
But.. even "locally".. as the all-Copper, plus "Eliptical Coil" top-end high-longevity model, no one wants to pay the freight or even haul nearly 400 lbs Avoir!
This one came out of McKean, about a 1,000 mile go-fetch for an under $200 purchase price, but.. I was also picking-up a nice B&S surface plate from McKean... and 5 Reliance RPM III Dee Cee motors from another outfit a few miles away, so..
Since deciding to re-motor wherever I could not simply re-strap rather than deal with 600 Volt-Class, I've had no takers on giving it away!
Similar deals will be "out there" in Canada. They just might be at rather a bit of distance from the Maritimes...
BFD.
Find one that fits the need PROPERLY. "At least" one set of "adjusting taps" is good. More is better. Then go-fetch or pay the freight. Run well and prosper with minimal kludge, reduced risk of marginal rations to the more important CNC rig.
Reduced inefficiency over looong years
will pay-off if yah "do it right" and can go "JFDI", worry-free, as to earning a crust with the machine.
Not as if you have to dig-deep into the beer, burger, and band-aids budget every
week, is it?
2CW
