Palak
- Jul 12, 2013
- Pacific NW
Just moved from a building with 208V 3-phase with equal voltage legs, to one with a 240V 3-phase with 120/120/240 high-leg system. Still trying to wrap my head around how a high-leg system works.
We have been using a transformer to step up voltage to 480V to run a grinder with a 20HP motor. This grinder has a heavy wheel (120 lbs), and draws a lot of current on startup. This 30KVA transformer is for 480V primary, 208V secondary.
When we moved to the new 240V system, we connected the transformer up with the same wiring, but used the lowest voltage jumper setting. The previous 208V input was set on Jumper 3 to yield 480V output. We set the Jumper to the lowest setting - for 208V, should yield 432 volts, but for 240V, is now yielding about 505V between each leg going to the machine.
Questions:
1. Will this voltage damage our grinder (running about 5% above required voltage), which requires?
2. Should we seek out a 240V-480V transformer, or will this one continue to work well, even though designed for 208V-480V.
3. The transformer is located about 90 feet from the panel. The input voltages to the transformer are 122V to ground on 2 legs, and 211V to ground on the high leg. On the output voltage, they read 508, 506, 506 leg-to-leg, but 236V, 270V, and 313V when measuring each output leg to ground? Stumped by this, and electrician was too? Any ideas?
4. For any gluttons for punishment or electrical sleuthing hobbyists, when we started up this grinder, immediately blew three 30A fuses on the disconnect box on the transformer. Electrician had to see this for himself, so we replaced the fuses, started up the grinder, and immediately blew 2 of 3 fuses again (different pair this time.) He was stumped, but tried switching the wiring to the disconnect box to heavier gauge wire (even though this wiring worked well on our 208V system), and we were able to start the grinder up no problem. He didn't know why this worked. Any ideas? We have only run this grinder for about 5 mins, and 2 starts, so don't know if this permanently solved the blowing fuse issues.
Any ideas much appreciated, and thanks in advance.
Questions:
