I have a 50VA 240/24V transformer driving, at different times as needed, one, two or three Central heating zones' 24V DC relays, 680 ohms each. DC is achieved using Bridge rectifiers type KBPC1-005 and 2200uF capacitors. The transformer replaced a failed smaller VA transformer. I designed and modified the system over the past fifty years. This is what happens:
with only the DC relays as loads, the DC Voltages at the relays'
coils are 35. As a Mechanical Engineer with a DIY knowledge of
electronics, I think that level of voltage could shorten the life of the relays. I tried to reduce the voltage by inserting a suitable resistor, after a fuse that was located immediately after the transformer's 24V output.
This worked fine and got my desired 24VDC at one relay coil. However, there was insufficient voltage to operate even one more relay.
I now think the capacitors and the transformer may be too large.
One potential solution, I thought, was to reduce the resistance as a second and third relay was activated, using a voltage value trigger. This is stretching my DIY a bit. Or is 35VDC OK on a 24-volt DC relay?
Please, is there a solution that does not include scrapping the new transformer?
Your help would be very much appreciated.
Best regards,
BillPall
Best regards,
BillPall
