Peter from Holland
- Jan 15, 2005
- The Netherlands
I have a transformer with on the primary side 0-220-380 volts Secondary 24 volts It is 100Va
I need it for a low voltage circuit on a paper band filter But i also need 220volts on that circuit to power a small 50Watt motor to move the paper band
It is connected with a special plug with no Neutral
So I did some testing. If I connect the transformer to 380 volts on the 0 and 380 lead I measure 220Volts between 0 and 220 Obvious
Can I connect that 50W 220volts motor to those 2 leads and still use the 24Volts side to control 2 contactors ???
Also How to fuse it
Peter
Also How to fuse it
Peter
