Transformer selection buck boost or other
cgmaster
Cast Iron
Jun 9, 2008
Ocean Springs, MS
I am installing a new Kitamura mill. I am running off of a phase converter. The input for the Kitamura is 200 to 220 max. I have about 245 coming from the phase converter. I am looking at transformers to correct the voltage. The mill rating is 30KVA.
What are my options?
I am looking at buck boost and think I would need a 16/32 volt. From what I understand I would need 2 transformers. I have never used buck boost transformers and will be reading about them tonight and how to connect them. any help would be appreciated.
Thank you.
I went through this with my Brother Speedio. Went with a pair of buck/boost transformers from McMaster-Carr, wired to deliver 208V. I was skeptical at the small wiring size within the transformers, but the system works great.
Regards.
Mike
This has been talked about at length. The KVA rating of the transformer is just the difference available and what's needed. If the machine needs 10 KVA and the line voltage is such that the supply will only be 8 KVA at the required current, then only 2 KVA are needed in the buck/boost transformer. The small wire is just for core excitation.
Tom
Would getting a standard transformer be a better idea? I can get a multi tap transformer that was on a Mazak a guy has 2 of them one is 52 KVA and the other is 34 KVA. Would using a larger transformer cause any problems? I can actually get either one cheaper than the Buck boost.
The mill I am using it on is 30KVA.
I have a Kitty that I run from a Phase Perfect with two buck boost transformers between the PP and the Kitty. My line voltage is 247. I could put a single buck boost in front of the PP, but since the PP is limited at a continuous current level, I actually gain max current by using a pair of BB transformers after the PP. In your case, if you are only powering the Kitty, it would be simpler to put a single BB in front of the rotary.
You could put one in front of the rotary, knowing of course that you will be totally isolating the load from the line. The green safety of course goes through. Will the loss of ground reference to the electronics cause a problem? There has been a lot of binary bits spilled on this subject without a definite conclusion. The other downside is a greater core loss (heat).
Tom
I ended up getting a transformer from a Mazak.
Here are the specs.
52.5 KVA Total
Input: 200-480V
200, 220, 230, 240, 380, 415, 440, 460, 480
Output: 42 KVA @ 210V - 3 Ph
0.8 KVA @ 100-115V - 1 Ph
2.5 KVA @ 100-115V - 1 Ph
7.2 KVA @ 180/200V - 3 Ph
I plan to connect it right before the machine. On my other machines I have the ground seperated from the main electrical ground however 2 people recently told me I needed to tie the grounds to the electrical service.
