Troubleshooting Emco MAXIMAT V13 Engine Lathe Power
Results 1 to 4 of 4
    Apr 2020
    Kansas
    Question Troubleshooting Emco MAXIMAT V13 Engine Lathe Power
    Problem: when I rotate the power switch on the Emco MAXIMAT V13 Engine Lathe the lathe does not operate. I hear and see no visual indication of power.
    I acquired an Emco MAXIMAT V13 Engine Lathe and I am wiring it up for the first time. I can not find any documentation from Emco on how to wire it up, but I took detailed notes on how it was wired up at it's last home.
    Breaker 220v -> Main Switch -> Rotary Phase Converter 3 Phase -> X Lathe
    From the Breaker I have 220v going to my Phase-A-Matic Rotary Phase Converter then 3-Phase power going to the lathe. When I throw the main switch, the Phase-A-Matic Rotary Phase Converter seems to run just fine. The converter sounds good and the RPM's appear to be normal. My problem is where the 3-phase power wires connect to the lathe. I'd like to verify that I have it wired correctly but I lack the Emco diagram. Can anyone assist with advice or diagrams?
    Thanks!
    Apr 2020
    Kansas
    Default Information Update
    Update: I disconnected the wires to the Lathe and metered them with the following results:
    T1-T2: 240v
    T1-T3: 220v
    T2-T3: 250v
    T1-N:121v
    T2-N:220v
    T3-N:98v
    I assume I correctly identified T1, T2, T3, and N.
    The new question is how normal are my readings?
    Jan 2020
    39
    17
    Quote Originally Posted by MadHattan View Post
    T1-T2: 240v
    T1-T3: 220v
    T2-T3: 250v
    T1-N:121v
    T2-N:220v
    T3-N:98v
    Lucky you!
    Try removing the back cover of the electrical box - the Super11 has the wire diagram. I bet yours does as well.
    Also, the inside cover of the motor junction box [small j-box attached to the motor] should show the winding-configurations. [Delta vs Double-Wye(Dahlander)] etc. This will just tell you how the motor can be wired, not how it is switched.
    German language manual here has a couple wire diagrams. Not sure if that's useful.
    https://www.emco.or.at/index.php/dow...anleitung/file
    https://www.emco.or.at/index.php/dow...viceteile/file
    For the Super 11 there were a few different versions - a plain and a 'safety electric' with different switch configurations -- safety electric has a second Yellow/Red rotary switch. There is a schematic manual for that. Let me know if you need it.
    There's an EmcoSuper11 group where i bet some folks know about your lathe. [email protected] | Home
    -Dave
  4. Likes MadHattan liked this post
    Apr 2020
    Kansas
    I got it to work thanks for all the help!
