MadHattan
- Apr 7, 2020
- Kansas, USA
Problem: when I rotate the power switch on the Emco MAXIMAT V13 Engine Lathe the lathe does not operate. I hear and see no visual indication of power.
I acquired an Emco MAXIMAT V13 Engine Lathe and I am wiring it up for the first time. I can not find any documentation from Emco on how to wire it up, but I took detailed notes on how it was wired up at it's last home.
From the Breaker I have 220v going to my Phase-A-Matic Rotary Phase Converter then 3-Phase power going to the lathe. When I throw the main switch, the Phase-A-Matic Rotary Phase Converter seems to run just fine. The converter sounds good and the RPM's appear to be normal. My problem is where the 3-phase power wires connect to the lathe. I'd like to verify that I have it wired correctly but I lack the Emco diagram. Can anyone assist with advice or diagrams?
Thanks!
Breaker 220v -> Main Switch -> Rotary Phase Converter 3 Phase -> X Lathe
Thanks!
