Trying to add external switch to Dust Collector
Likes Likes:  0
Results 1 to 2 of 2
    Jun 2015
    366
    69
    87
    Default Trying to add external switch to Dust Collector
    Questions for electrical types. I bought a new dust collector. My previous one was homemade. It has a 1/3 or 1/2 (canít remember) hp motor which turned on and off from basically a light switch. The new one has a single phase 120V 1.5 hp motor. The on/off switch that comes with it is pretty cheesy. It has a keychain remote and momentary buttons for on and off on the case.
    Iíd like to turn this thing on and off from multiple locations around the shop including a relay output from the CNC router where the on off commands can be embedded in the g code. Digging into this thing, it appear the on and off signals from the switch are momentary. Pictured: terminals 1 and 2 connected momentarily turn it on, and momentarily breaking the normally closed 2-3 connection turn it off. I was hoping to tee into this with relay outputs, but they wouldnít be momentary signals.
    Is there a way to get a momentary output from a continuous one? Iím not sure it there is a type of relay for this.
    Alternatively, I could chuck the whole can and replace it with a presumably better motor starter, but Iím not sure which type I need. Maybe this guy: mcmaster (motor says 19A @120V, 10A @240V, so Iíd rewire it for 240 while Iím at it)
    Advice is appreciated.
    Jun 2015
    366
    69
    87
    Talked to dude on tech support. He was very helpful. The board runs the remote, so I can chuck it in the trash, pull the blacks and whites from the board and switch those directly from a relay. The only overload protection is 25A circuit breaker, so I guess a motor starter is not required.. Thanks
