ezzzzzzz
- May 5, 2008
- Portsmouth, Va
I've wired up my WJ200 using an Eaton power relay (240v). The 115v control is initially activated using a momentary power switch. It is latched by being back fed from one leg of the load side of the relay. The neutral side of the latching coil goes through a stop button. Applying power energizes the coil latching the relay feeding 240 to the WJ200. The problem is the relay buzzes loudly. You can feel the relay buzzing and pressing on it doesn't quiet it down. Is there suppose to be some type of bleeding resistor or capacitor to to eliminate this? Is the relay bad or just my install?
Second, I've wired in a run button through a forward and reverse switch to the first 2 intelligent inputs. I've set the parameter A002 = 01 but the switch doesn't command a response (the bridgeport doesn't start to run). Any ideas?
