I have a VFD controlling a 3 phase motor that I wish to control from two seperate panels depending on which side of the lathe I'm using.
On the main side is start/stop momentary push buttons, a 2-pos fwd/rev switch, and a pot. On the other side is start/stop and a pot. Ideally I'd like to set the VFD frequency source to the pot belonging to the side that started it.
I can't think of any elegant way to do this without giving up the start/stop buttons for a single latching button each side, or relays, or a PLC. Is there an obvious solution?
The drive is a delta VFD015B21A.
Thanks in advance as always
