ProSeriesRacing
- Aug 9, 2018
Hello, need help wiring for 220 and 110 voltage for Forward & reverse operation.
Confused by the diagram, which way is the lever (top or bottom) and what they call the front and rear terminals (top or side) orientation.
Have the 220 wiring figured out on the motor, grouping 2,3,5 together, 1,4 and 6 on individual terminal studs. Have red & 6, black & 1, white & 4 on separate studs.
How do I connect to the switch for 220 operation?
For 110-120 voltage, group 1 & 3 than 2 & 4 on individual studs and have 5 & 6 on separate studs?
Than the connection to the GE switch?
Using GE CR102B 313A switch
Here is several photos for review
