I've been in a shop without 3 phase power for the first time for about the last 3 years or so. I have needed a new compressor since my larger one, an Ing. Rand T-30, got damaged in the last shop move, and finally ordered a Kellogg 452 pump and two Baldor motors - one a 10 hp the other a 7 1/2.
I am currently operating with a 3 hp RPC a buddy gave me which starts a 7 1/2 HP idler that easily runs a 3 hp compressor and either of two B&S screw machines or one 20 spindle drilling and tapping machine or a horizontal milling machine along with the compressor. But I need more air as I also run in about 25 to 30 K screws a year with an air driver.
One of the B&S machines has an air drill on the front slide and the drill/tap machine has an air over hydraulic clamp. The drill press has a air power feed and is used in production work as well.
The drilling/tapping machine has an air over hydraulic clamping fixture and an air nozzle is used continually to blow chips out of the fixture which slides along rails back and forth between drilling and tapping heads - air powered of course. And the heads themselves power down to the parts before the lead screw kicks in, by air of course. I need lots of air.
I have never attempted balancing out the voltages with capacitors, and it seems that the more motors are run in the circuit, the less effective the balancing becomes. I checked the voltage on the B&S that runs the motor starters hot and found that the generated leg was 277 volts as opposed to 220 and 220 on the power company legs. That was taken with a Fluke model 322 class III tester - whatever that means.
The current was also all over the place.
However, that machine's spindle motor starter ran hot on good power-company 3 phase when I bought it used. Someone had added a box with capacitors in it, and there was a pile of motor starter heater insert things in the machine electric box.
So I just run it for half an hour and let it cool down before cranking it up again. It sounds a lot like the problem Coountry Boy 19's father has here http://www.practicalmachinist.com/v...ning-multiple-motors-rotary-converter-343135/
What I've done before with 2 compressors (and regular 3 ph. power) was to start both compressors off the same pressure switch, but use an on-delay timer for the control voltage to start the second, and use a separate circuit from the main panel for the high voltage to run that second compressor. Then I didn't have to screw around with trying to pull heavy wire through the conduit nor have such a huge inrush at startup.
So I don't know what the best way to go is. One RPC started with a "3 hp" rpc consisting of two 7 1/2 HP idlers and one panel?
Or should I split them up into two circuits in different panels with the same 3 hp RPC starting a 7 1/2 hp idler starting only a 10 HP compressor while the rest of the machines run off the 3 ph rpc starting a different 7 1/2 hp in a different 3 phase panel? It seems that that way would make it easier to balance the voltages - which I've never attempted before. I'm guessing that the 3 hp plus the 7 1/2 hp would start the compressor 10 hp motor. I plan to let it run down to 90 psi before it trips the pressure switch.
I could also get head unloaders for the compressor so it would become a continuous run motor. The guy I talked to that seemed to definitely know his stuff really didn't like that plan (and he was the one who'd sell me the head unloader kit) - saying that continuous run sucks oil out of the reservoir really fast and can cause big problems. So I can relate to that guy, especially since he will be losing money by talking me out of it. But I do the same thing with my product because I don't want them to be coming back because somebody is using them for an application they weren't designed for.
I've only had one continuous run compressor, a 5hp Emglow single phase wheelbarrow for construction work, and I burned out the motor and screwed the pump by spraying continuously for too long a period of time with the compressor outside where I couldn't hear it or the rain.
Ox, my brain is getting as squirrely as my squirrel mail. I finally checked my old messages and saw that you'd already recommended the lube for the screw machines running only brass that I posted another question about. It was so long ago (at least 3 months) I'd forgotten about it. Anyhow, I just got in 60 gallons of new hydraulic oil for the screw machines and another 15 for various other things. So I thank you for your generosity and advice based on actual experience. This place is a great resource.
So I got my Christmas presents sittin in the shop, with more comin.
Merry Christmas all. Any thoughts on the above would be greatly appreciated.
Cheers,
Jim
Cheers,
Jim
